3 members (TeW, Hotrod Lincoln, homer52), 65 guests, and 0 robots.
Topics128,049
Posts1,055,638
#237957 07/27/2007 4:14 PM
Well I tried searching but couldn't find much on what I need. My question is at what point if any does the grill get larger on our trucks. I have a spare grille that was gotten some years ago, My dad says it won't fit the truck and is for a larger truck. My truck is 3/4 ton, I didn't know there was a difference in the front grille for a1/2, 3/4, 1 or 1-1/2 ton or is there?
I have to get the grill out of the top of the garage but have not yet, been busy messing with the brakes. Just curious.
Birge
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
#237958 07/27/2007 4:22 PM
The grilles are the same and interchangeable from 1/2 ton to 1 ton in the Advance Design series.
Steve
'49 3800
'52 3600
'57 3100
#237959 07/27/2007 4:29 PM
well thanks this may be good news, or it may be a grill for 1-1/2 I will get it down and see
Thanks Steve
Birge
Birge
#237960 07/27/2007 5:31 PM
On AD trucks, the horizontal bars are the same for all trucks. The vertical uprights that the bars are attached to are the same for 1/2, 3/4, and 1 ton. 1 1/2 and up, the uprights are a little taller.
#237961 07/27/2007 5:56 PM
Well I think this must be a grill for a 1-1/2 then but I will check it out. I may be able to use part of as one of my horizontals is bent pretty good from some kids running the truck into a tree. Really didn't do much damage othr than know off the front bumper broke a braket, bent the grill and of course ran the motor in to the radiator a bit. All that has long sice been removed or repaired.
Apparently it was dark and someone pulled the t knob, thus accelrating and smack into the tree.
Birge
Birge
