1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’m trying to more fully understand which 6 cylinder engines were available over which years in both Chevys and GMC’s. Also what the basic differences were.
I know this has been discussed here many times, but I can not find a single complete listing. (Maybe I’m not looking hard enough) I know Barry has done several Tech Tips on the subject
I would like to send Peg a single sheet that lists the following info (assuming it’s not already available)
Years the engine was available Was it available in cars, trucks or both Was it a Chevy or GMC Displacement Valve cover bolt arrangement Height of the side cover Pressure or splash oiling Babbit or insert bearings
I believe the various displacements include 194, 204, 216, 235, 261, 270, 302 and most likely several more | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kip's41, I would suggest you set some parameters, first year, last year, and truck size for starters, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kip, Last year, Warren Foster & I put together the following pages for 1929-1962 stovebolt engines (Chevrolet in-line six cylinder engines derived from the 1929 194 cubic inch "cast iron wonder" stovebolt six). We have not yet made a set of similar pages for GMC in-line six engines from the same era but we could do so. A few months ago, I think I offered these pages to Peg as a suggested Tech Tip. Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Tim, http://www.1954advance-design.com/ , great site, been there many times for research and really appreciate your effort. That chart pretty much covers the subject. I see you collaborated with Warren Foster on some of the material, good guy, I bought parts for my 3604 that I couldn’t find anywhere else. I was wondering about something while printing out the chart from your site this morning. I have to print everything out in landscape or I loose the right hand margin. Is this a quark of my software or is this the way you have it laid out? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Early on GMC used Olds and Pontiac sixes if I remember right. I think from the flathead era, though I'm sure not an expert on those.
The light truck GMC overhead valve inline sixes are as follows:
228 248 270 302
I believe there are military versions of both the 270 and the 302 and both were available pretty early. The 228 and 248 are the standard motors in '47 to '54 1/2-ton stuff. The 270 was used in pickups starting in the late 50's I think.
When GMC started installing V-8's in pickups they used Olds and Pontiac motors again.
While the 2-ton was the largest truck Chevrolet made, GMC made bigger ones, and there are larger GMC sixes out there. I know little about them.
About '63 GMC introduced V-6 and V-12 motors which replaced the inlines in both the light and medium duty trucks.
A complete and accurate application guide would be a great thing to read. I sure don't have all the information, but the first place I'd look would be OldGMCTrucks.com.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2004 Posts: 22 Junior Member | | Junior Member Joined: Nov 2004 Posts: 22 | From the 12th Edition of the Motor Truck Repair Manual:
GMC big sixes: 318, 360, 426, 503.
Pat | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | and 6-71 from the same era. | | |
