1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 116 | with out cuting the frame ?
LEWIS
| | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | I've got 265s on my '63 fleetside with room to spare. You can go as wide as you want without cutting the frame.. it's the fenders that would have to expanded.... offset rims.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | It all has to do with the offset on the rim you're using. A good tire/wheel shop can help you out there. You might find one that has a setup rig that bolts to your rim & shows the fit at different offsets and tire sizes, but thats a bit rare unless they do alot of custom work.
You'll always be able to fit more under the rear than the front as you have to look at what sort of clearance you need as full turn for the frame and fender. One reason why you'll see some rigs with smaller front tires. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A 32x11.50x15 is about as big as you can go without rubbing in the rear fenders.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 116 | rite now its got mud tires on it 31x10.50's. but its becomeing wat i guess u could call pro street im going to put biger fender wells can i run 33x21.50's?
LEWIS
| | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | 275x60s on 8" rallys,no hauling,no problems | | |
