Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
10 members (TUTS 59, homer52, Guitplayer, Hotrod Lincoln, 32vsnake, Charles in CA, Peggy M, 46 Texaco, 2 invisible), 556 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
with out cuting the frame ?
LEWIS
I've got 265s on my '63 fleetside with room to spare. You can go as wide as you want without cutting the frame.. it's the fenders that would have to expanded.... offset rims.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
It all has to do with the offset on the rim you're using. A good tire/wheel shop can help you out there. You might find one that has a setup rig that bolts to your rim & shows the fit at different offsets and tire sizes, but thats a bit rare unless they do alot of custom work.
You'll always be able to fit more under the rear than the front as you have to look at what sort of clearance you need as full turn for the frame and fender. One reason why you'll see some rigs with smaller front tires.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
A 32x11.50x15 is about as big as you can go without rubbing in the rear fenders.
Bill Burmeister
rite now its got mud tires on it 31x10.50's. but its becomeing wat i guess u could call pro street im going to put biger fender wells can i run 33x21.50's?
LEWIS
275x60s on 8" rallys,no hauling,no problems
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.062s Queries: 13 (0.059s) Memory: 0.6139 MB (Peak: 0.6629 MB) Data Comp: Zlib Server Time: 2025-09-22 16:00:17 UTC
Valid HTML 5 and Valid CSS
