| | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Hi guys, I have a 1951 Chevy 3604 and I want to put new tires on the split rims. I did several searches and came up empty handed. My problem is, I'm not 100% sure what size the split rims are. The tires on there currently read: 7.00 - 15LT, so I would guess they are 15". I'm sure you're thinking "Duh!" but I want to be sure. I measured from the outside of the lock ring to the other outer side and it measures 17". But inside the ring measures 15". I don't know much about tires at all (obviously) so that's why I'm asking the pro's. I do know a couple of guys who can put new tubes and tires on for me. But my next question is, who can I buy white wall, tube tires from? Coker, Classic White Wall Tires, and other suggestions. I don't think anyone locally carries them, I've checked with a couple of local tire dealers. Thanks for the help guys. Jeff Lincoln, Nebraska | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Jeff, Yes, your tires are 15", which were standard on the base 3/4 ton pickup. 17" tires were also an option. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | If you are not aware, split rims can be down right dangerous when mounting tires. Do a search here and some reading on these things. | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Thanks Ghostrider, I know they are dangerous but my mechanic says he's just a dumb Bohonk and is still willing to work on them, he has a cage and everything he needs. Does anyone have any suggestions on where I should buy the tubes and tires (white walls)? Thanks, Jeff. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Any tire shop that sells truck/farm/trailer tires should have the tubes with the TR150 stems (the long bendable rubber stems that come out near the center) and the flaps or liners that go between the tube and wheel. I don't know about the wide white wall tires, sorry.
Professional Novice
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | | | |
