| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | About to buy some Firestone 650-16 tires for the half ton and they are available only in 4 ply rating. The truck will not be subject to any heavy loads or speeds above 50-55 mph. Will 4 ply be okay? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | If they are 4 ply rated,they are probably 2 ply tires ratred at 4 ply.They should be all right with no load or minimum loads. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't really see a problem, I think that the 4 ply tire was the base tire on the 1/2 tons. Just make sure that you keep the tire pressures to the spec for the truck. That'll be listed in the owners manual.
Bill Burmeister | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | look on the sidewall to see what the tire will carry at max inflation. Multipy by 4 and that will tell you how much weight tires will hold. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Under ideal conditions, inflated to maximum permissible temperature, with rims in good condition, nuts torqued, etc. 1951 3800 Be the change you want to see. -hotshoe
