3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#237388 07/17/2007 5:32 AM
About to buy some Firestone 650-16 tires for the half ton and they are available only in 4 ply rating. The truck will not be subject to any heavy loads or speeds above 50-55 mph.
Will 4 ply be okay?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#237389 07/17/2007 12:34 PM
If they are 4 ply rated,they are probably 2 ply tires ratred at 4 ply.They should be all right with no load or minimum loads.
#237390 07/18/2007 2:21 AM
I don't really see a problem, I think that the 4 ply tire was the base tire on the 1/2 tons. Just make sure that you keep the tire pressures to the spec for the truck. That'll be listed in the owners manual.
Bill Burmeister
#237391 07/18/2007 4:10 AM
Apprentice
Apprentice
look on the sidewall to see what the tire will carry at max inflation. Multipy by 4 and that will tell you how much weight tires will hold.
#237392 07/18/2007 2:55 PM
Under ideal conditions, inflated to maximum permissible temperature, with rims in good condition, nuts torqued, etc.
1951 3800
-hotshoe
