1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#237367 07/16/2007 10:19 PM
I am looking for suggestions on how to remove the hood to cowl gasket without removing the hood. I have all but two of the clips off that hold it down....the two that I can't reach are the ones that are located as the gasket turns downhill. I have a 5/32 clutch bit but can't get the leverage to get them started as they are rusted. They have been soaking in PB Blaster for a couple of days. Any ideas? :confused:
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#237368 07/16/2007 11:20 PM
If you want to be tricky about it, you could support the hood, undo the support springs and undo one hinge swivel on each side. You would need to guide the hood but it will move to a different resting place for you. This may or may not help you, only you can decide.
1951 1 Ton Completed
#237369 07/17/2007 5:39 AM
Are the screws long enough to begin an attack on them from under the dash?
1948 AD Pickup
#237370 07/18/2007 12:10 AM
V
V Offline
I know the ones on my truck can be seen from under the dash.
#237371 07/18/2007 4:59 AM
Mine too Virginiafiretruck, like about an inch long hangin' down there........
1948 AD Pickup
#237372 07/18/2007 2:55 PM
i made a clutch head driver out of a 3/8 drive alen wrench, and removed mine with the hood on, worked great,,
#237373 07/19/2007 12:29 AM
pushrod,
I can see how that would work. There is not much room to get a grip on that screw, is there?
How did you go about making yours? I used my clutch head bit in a 1/4" drive ratchet, but then ran outa room on the two that I mentioned. I then used a 3/8" combination and put the bit in the closed end....need another hand to make it work though!!!
littlebuddie,
I think if worse comes to worse I might try going after them from the inside but was worried about damaging the threads and then not being able to ever remove them.
Blue 50
1950 3100 w/57 235
