0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Hi
I'm busy with putting my 55 1st serie chevy Pick up togther after 9 Years in the garage!!
Well, I have two problems with the hood.
When I have the hood springs mounted there is stil a big gap between the hood and the cab with the hood closed. I can push it down with my hand but it will not stay there because of the hood springs. If I leave out the springs it will close normal. What can I do??
The second thing is when I have the hood closed and I look at the fenders, the hood needed to be adjusted to the right, but it will make the gap differnce worst between hood and cab. Do I have the cab fenders not sit strait on the frame???
I tryed messuring the cab and fenders from the frame and it seems to be all right. Any suggestions would be appreciated.
Sorry my spelling might not always be right, I'm german | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Guten tag, das Willkommen das Forum. (something like that, right?)
I know others will join in soon. But aligning the body panels can be a challenge. Just take your time and be patient. You'll get it.
Jim | | | | | | Anonymous Unregistered | | Anonymous Unregistered | http://ares.cs.siena.edu/~lederman/truck/Documents/HoodAlignment/AD_hood_alignment.htm
look at this site it may help you. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the main problem with the back of the hood not laying down on the cowl when the springs are in is worn hinges - replace them with new or very good used and most of your problem will be solved
Bill | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I had basically the same problem with the hood on my 54. Couldn't get the back to fit tight on the cowl strips which threw everything else off. I was ready to spring for new hinges but I gave it one last shot. This is what I found out to completely solve the problem:
1. Get 2 friends to help. One on each side of the hood up close to the windshield.
2. loosen the 1 bolt on each of the hinges that you can see with the hood raised.
3. Close the hood and put a 4" block between the hood latch and the hood striker plate.
4. Loosen the 2 bolts on each hinge from under the dash. You won't have to take out the glove box on the passengers side.
5. Have your "assistants" push down and towards the windshield on the top curve of the hood at the same time.
6. Tighten your inside bolts while they apply equal pressure to both sides. That's why you need two!
7. Remove the block, tighten the one bolt on each side and carefully lower the hood so you don't scratch up the paint. Check your fit. Mine started out with a 1" gap which completely disappeared....it lays tight against the rubber strips.
8. I made a couple adjustments in the rods that tie into the firewall and the fenders. You may have to loosen some of the upper core support bolts if you have to make more aggressive adjustments.
Give it a shot...doesn't cost anything to give it a try!!!
Dave | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Back in the dark ages when I was a bodyman the primary causes of the symptom you describe were two: One is as Bill noted, the hinges are worn and need to be replaced. Two, and by far the most common, oil. Lubricate the hinges and often magic happens. I can't tell you how many times "sprung" or "worn out" hinges were "fixed" by a few drops of oil. Don't even try to align your body panels until the hinge problem is fixed.
| | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Thanks for the Help,
I will try to work on it on Thursday, hope I get it to work. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have the same problem so keep me (and all of us) in the loop! I'm trying to get it right! | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | What worked for me was I loosened the hinges where they bolt to the cab. Then I had somebody push the front of the hood up as far as they could, and while they held it I tightened the bolts. The hood laid down real nice then.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i little work, and a lot of patients got mine fitting finally. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "a lot of patients"? how many? were they mental? Bill | | |
