2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#236646 07/10/2007 6:28 AM
I plan on switching back to a stok location gas tank (behind the seat). What are the differences between the 48-55 1st and a TF truck? Will the early tank fin into a TF truck? I notice the earlier tank has a bottom feed and the TF tank feeds from the sender assembly. If the earlier tank will fit into a TF truck, I would like to change the feed from 5/16 to 3/8. Also what are the differences in the senders? The previous owner installed a plastic fuel cell under the bed and it fills with water during heavy storms. I'm done with the fuel cell :mad: .
TIA
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
#236647 07/10/2007 10:05 PM
I can't help you with the main part of your question, but I can tell you that the '48 tank is under the bed, not behind the seat, like later trucks.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#236648 07/10/2007 10:36 PM
For some reason I think the earlier (49-54??) feed out the passenger side and the 55+ out the driver side? (as in I don't think they can be swapped at all)
Someone verify this.
#236649 07/10/2007 11:39 PM
no they will not fit, the gas line (tank to carb)comes into the bottom a tank a couple of inches in difference from the TF to the AD, and the filler necks are at different heights. i bought a new tank for a 55-59 and found all this out after looking at putting it in my 49.
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#236650 08/05/2007 6:01 AM
I now have a 55 2nd series tank, I was going to order a new sender, but the sender fuel line size is 5/16. I noticed that there is a fuel tank drain at the bottom of the tank. Has anyone tried soldering a 6AN fitting to the bottom of the tank and using 3/8 braided hose to the fuel pump? I know the sender hole is the same size as the autometer sender that is used in the JAZ fuel cells, so installing a sender without the pickup tube is not an issue.
