7 members (lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible), 128 guests, and 1 robot.
Topics128,049
Posts1,055,553
Members48,425
#236639 07/03/2007 12:00 AM
I thinking about moving a cross member and was wondering if the frame flanges can be drilled with a hand drill? Has any one done this? I'm concerned the frame could be a hardened steel
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
#236640 07/03/2007 1:02 AM
Hi Eric, Can't tell you about a 57 but a 51 has mild steel frame rails. They can be drilled and cut with a sawzall!
Rick
#236641 07/03/2007 1:29 AM
Sure, I have drilled many with just a cordless drill.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#236642 07/03/2007 1:29 AM
Hey Eric, Grant here. Have at it... the frame is mild steel, allows flex, and drills quite well. I suggest some light oil to keep your drill bit cutting efficient and cooler. Start small, and open up in steps... you'll get a better hole. Grant.
#236643 07/03/2007 1:36 AM
I own a 55 1/2 ton, and I don't think the frames changed much in two years. I have drilled many holes with a hand drill by first drilling a 1/8" hole and then drilling to the final size. I found that drilling the smaller hole first reduces the force required to drill the large hole and prevents the bit from moving off.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
#236644 07/03/2007 8:33 AM
Same here , Mounted many new things with a cordless drill ...
1952 Chevy Shortbed
Photos in Photobucket
#236645 07/03/2007 7:51 PM
I use my 18v battery powered drill on all sorts of metal... your drill should be good, assuming you have the correct type of drill bits.
Another quality post.
Real Trucks Rattle
