| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I thinking about moving a cross member and was wondering if the frame flanges can be drilled with a hand drill? Has any one done this? I'm concerned the frame could be a hardened steel | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi Eric, Can't tell you about a 57 but a 51 has mild steel frame rails. They can be drilled and cut with a sawzall! Rick | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sure, I have drilled many with just a cordless drill. Grigg | | | | | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hey Eric, Grant here. Have at it... the frame is mild steel, allows flex, and drills quite well. I suggest some light oil to keep your drill bit cutting efficient and cooler. Start small, and open up in steps... you'll get a better hole. Grant. | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I own a 55 1/2 ton, and I don't think the frames changed much in two years. I have drilled many holes with a hand drill by first drilling a 1/8" hole and then drilling to the final size. I found that drilling the smaller hole first reduces the force required to drill the large hole and prevents the bit from moving off. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Same here , Mounted many new things with a cordless drill ... | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I use my 18v battery powered drill on all sorts of metal... your drill should be good, assuming you have the correct type of drill bits.
