0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | on my 67 283 the battery almost melted theres a bracket on the front that goes up and bolts to the block . Well it came loose and fell on the cable and starter things got hot and I got a tow home so now i got new cables and everything is fine except i cant get the front bracket back in can i go without it i see most starters dont even have the front bracket is it realy needed if so mayby i can get it jacked up enuff theres not much room for to top bolt because of the manifold let me know what you think thanks guys for the help | | | | | Joined: Mar 2006 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 72 | On my last 283, that bracket saved me from a walk home when one of the starter bolts broke. It was just enough to hold the starter in place with one bolt. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 32fire2, Your right, most starters don't use the front support, and there doesn't seem to be a lot problems caused by that, just make sure the bolts holding the starter to the engine are torqued to spec., hope that helps. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yes i will make sure the starter bolts are tight they may be loose also | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i just wanted to make sure it wouldnt crack the starter mounting or housing but it sounds like it will be ok | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Never even seen one with a front bracket. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I didnt put the bracket on my 55 for clearance reasons.The starters been on for 4 yrs. with no problems. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the starter has three bolt horizontally into the bell housing it doesn,t need one. If it has 2 vertical bolts parallel it does need the bracket. If the vertical bolts are staggered It doesn,t need it but it is beter with it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
