2 members (Otto Skorzeny, baldeagle), 107 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#236506 06/29/2007 8:51 PM
I have the grille ready to be installed on my '48 3100, but the fasteners are long gone. It looks like I need a lot of those J-clips, but I don't know what to look for. Would someone who has installed an AD grille tell me what I need?
I have a grille kit, but other than the nuts and bolts needed to attach the grille bars, there are only ten J-clips and corresponding clutch head sheet metal screws. I'm guessing these are for attaching the grille assembly to the splash pan, but they seem kind of small for that. Also, how do I get to those top two bolts (or whatever) that are behind the parking lights? I don't believe the parking lights can be put in after the grille assembly is on the truck.
ohwell
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#236507 06/30/2007 12:00 AM
There are many suppliers out there that should carry that hardware. My first vendor I would look to would be LMC.
http://www.lmctruck.com/icatalog/ca/t.asp?page=38
~Jim
#236508 06/30/2007 12:55 PM
Thanks, Big Chevy 3600, but I actually have two of those hardware kits, and other than the ten J-clips mentioned above, all they contain is the grille bar mounting nuts and bolts.
1948 Chevy 1/2-Ton
#236509 06/30/2007 1:50 PM
#236510 06/30/2007 5:06 PM
It seems like you've put your truck the same way mine is going together, ChuckTheTruck - put it together, take it apart, add something, put it together, repeat, repeat, repeat....
Can you remember what the fasteners were to mount the grille assembly to the fenders, splash pan, etc? I have to buy some.
1948 Chevy 1/2-Ton
#236511 06/30/2007 5:24 PM
Tom R, The parking lights can be mounted last..
Just leave the lens and bezel off the lamp before
installing....It also seemed like a grill fastener
package had everything necessary to build My grill
back after having it chromed...Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#236512 06/30/2007 6:18 PM
The grill to lower splash pan bolts are #14 hex head sheet metal screws inserted into J-nuts in the splash pan. They're not included in the grill bolt kits. I believe they're 1" length and you can get the J nuts and bolts from Restoration Specialties, among others. I don't have the part # handy right now but I can find it later if you'd like. I seem to recall needing about 20 of them all together for the lower splash pan, 1 on each fender and a couple on the upper baffle. The other bolts are just 5/16" course thread hex head bolts that thread into weld nuts on grill side bars and braces.
The small J nuts and clutch head screws in the kit are for the end of the grill bars, where the inner and outer bars come together.
Bob
#236513 06/30/2007 11:34 PM
Thanks, brjr. That's just the information I was looking for!
1948 Chevy 1/2-Ton
#236514 06/30/2007 11:52 PM
Go to a body shop supply store. They have loads of specialty fasteners,,thats where ive found all my clips,t-bolts,etc...
Good luck,
Marty
