| | | Forums66 Topics128,050 Posts1,055,758 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I don't have my shop manual with me right now. Can somebody help me out with a lower ball joint torque spec for '65 C20? Appreciate the help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mugsy, I only have a 69 manual available at the moment, spec for 69 is 215 ft. lbs., C10 spec. is 120 ft. lbs., hope that helps. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | 215! No kidding. I was figuring 150 or so. I'd imagine '69 is the same as '65 as the front end is pretty much the same thru '72. Thanks. | | |
