2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Working on my '54 Bel-Air again. Can the grille parts be re-chromed? I'm unsure if my grille parts are mild steel or stainless, but the chrome plating is coming off. Can it be re-plated?
Anybody use Tri-City Plating in Elizabethon, TN? My bumpers and stuff need plating, and I want to send this stuff out soon.
Thanks! Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Shouldn't be any problem having the parts re-plated, as long as they're in decent shape. And even if they aren't in real good shape, a good plating shop should be able to repair them. BTW-the grill should be regular steel, stainless would not have been plated.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | as LONGBOX said ...A good shop can do wonders , it may be pricey ...i had the grill in 75 Laguna redone had a few small dings in the pot metal ...they fixed it like original... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | sw radical I noticed your radiator overflow bottle hidden behind the inner fender. How do you refill that?
~Jim
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Hey Tim Nice lookin truck I would be very careful power washing a radiator. Did that once and ended up with scrap. Had about 20 holes blown in it. BE CAREFUL | | |
