4 members (baldeagle, walter74, BillCollins, Cosmo), 87 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#236031 06/21/2007 12:29 AM
Took ‘41 out for a leisurely drive around the block last night. First time since October, there are now 21 miles on the odometer all from going around the block. It started right up after a couple of drops of gas into the carburetor. On the first time around I realized that I must have incorrectly positioned the speedometer needle as it was showing 40 MPH and I was still in 2nd gear (not likely with the stock 4.56 rear end) On the second time around The needle fell off when the truck hit a bump in the road. Guess the needle needs to be glued to that skinny little post. Anyone ever have one of these speedometers apart and know how to hold the needle on??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#236032 06/26/2007 5:50 PM
Kip, I just took my gauge cluster out Sunday. I'm rewiring everything and I took it out to see what I can do to clean it up. I'll take a look at mine for ya. speaking of speedo cables...I need to get one. ha-ha!
Dean
#236033 06/26/2007 9:51 PM
Send me your e mail address and I'll send my dash before and after photos
#236034 06/30/2007 4:43 PM
Kip:
I built a good speedo out of parts from a bunch of broken ones. (I don't recommend it unless you've got a few days to putter around, BTW)
IIRC, there is a small clip or a nut or something that holds the needle on. I will look at my spare parts and see if that is the case or not.
I'll let you know.
#236035 06/30/2007 6:31 PM
for anyone else reading, I did look mine over and sent pics to Kip41. The speeedo needle has a small hub/cap pinning the needle down onto the post.
