1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Hello, I was wondering if there is a way to repair the hood hinges on my 1960. When I close the hood they don't want to settle down in the rear of the hinge. Enough so it doesn't even touch the cowl seal. I have tried re-piening the rivets that hold it together no luck. Anyone have any suggestions beside an allout replacement. Thanks in advance for all replys as usual!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Hey Beewrangler, where are you located in MN? Brian | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The problem is that the hinge pins are worn out. I had the same problem with my '55. you can get new hinges from any supplier, like American Classic.
Bill Burmeister | | |
