Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#235999 06/19/2007 7:49 PM
Hello,
I was wondering if there is a way to repair the hood hinges on my 1960. When I close the hood they don't want to settle down in the rear of the hinge. Enough so it doesn't even touch the cowl seal. I have tried re-piening the rivets that hold it together no luck. Anyone have any suggestions beside an allout replacement. Thanks in advance for all replys as usual!
240,000 worker bees!
1960 Two ton Chevy
#236000 06/19/2007 8:22 PM
Hey Beewrangler, where are you located in MN? Brian
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
#236001 06/19/2007 8:46 PM
The problem is that the hinge pins are worn out. I had the same problem with my '55. you can get new hinges from any supplier, like American Classic.
Bill Burmeister
