2 members (Otto Skorzeny, DennisM), 91 guests, and 5 robots.
Topics128,026
Posts1,055,403
Members48,422
#235899 06/18/2007 3:46 PM
Apprentice
Apprentice
Did the rear fenders 0n a 1950 3100 originaly have fender welt between the fender and side panel?
save a camaro,run a straight axle
#235900 06/18/2007 5:34 PM
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=003497#000000
#235901 06/18/2007 8:49 PM
Just a suggestion....I used the fender welting on my 54.....it would make things easier if you would drill an additional hole in between each of the factory holes on the front fenders. A nut and bolt are used for these and the additional holes will insure that your welting stays in place. Also, I used some very thin 2 sided tape to attach and hold the welting to the front fenders. Making sure that the fender lip is not bowed out will insure that your welting goes in straight and stays that way.
This drilling is best accomplished BEFORE you start bolting on the fenders. Adding the welting really gives the fenders a "finished" look. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#235902 06/19/2007 3:55 AM
FYI I bought my fender welt at a Volkswagen aftermarket accessory shop in town. It was about one-third the cost of Chevy supplier's prices.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
