7 members (52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible), 78 guests, and 0 robots.
Topics128,049
Posts1,055,629
#235869 06/18/2007 3:08 AM
When greasing my shackles I noticed that the grease only 'escaped' from one side of the shackle under pressure,near the fitting.
I know that you should not over grease but am wondering if the grease only comes out the one side of the shackle bolt, is the whole bolt getting grease?
I hope my question is understandable.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235870 06/18/2007 3:31 AM
Your question is understandable. If surplus grease comes only from one side, it is most likely that the shackle is stressed towards the other side. Don't worry. As soon as the bushing begins to work (on the road) the grease will be evenly distributed through the bearing surfaces.
1951 3800
-hotshoe
#235871 06/18/2007 5:01 AM
I might add that on two of the bolts, on the fixed end of the spring assembly, it took a lot of pressure to pump grease into it. Using a manual grease gun.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235872 06/18/2007 5:25 AM
Either the nipple is seized or there's too much muck packed inside the channel. Buy some replacement nipples: in straight, 45 and 90 degree inlets. Take the old one out, and to test it run a bit of grease through it. If it flows well, the problem is deeper. That being the case, you can usually clear the mess just inside there with a pick. An additional measure is to soften the muck a bit with a propane torch. Heat it gently. These measures have rarely failed. When you're done, grease it more often. That will keep things happier in there.
1951 3800
-hotshoe
#235873 06/18/2007 4:42 PM
Thats what I ran into, I just gave up. Its been like this for how many years? So it can just stay like that.
...this is by no means "advice".
#235874 06/19/2007 12:18 AM
I have no troble getting the grease through the nipples. The shackles/bolts are new as are the nipples with about 500 miles on them. I like playing with the grease gun so I usually lube all the fittings every 1000 miles. In the case of the shackle bolts they were greased when installed and I have greased them twice since.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235875 06/19/2007 3:51 AM
Junior Member
Junior Member
A little more work, but if you can jack up under the frame to relieve the loading on the springs, you just might be able to get the grease to go in a little bit easier. That should cause the grease to more evenly coat the shackle bolts.
"Age is only relative- - -It's just that some of us have more relatives than others"
#235876 06/19/2007 3:53 AM
Actually I was talking to a truck guru about it and he said the exact same thing! I am glad we have so much talent on this Forum, sure helps. We don't know it all but each of us knows a little something and it adds up.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
