2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Hi All,
My truck never did sit level when viewed from the rear, one side of the bed was higher. The bed is off now and there is about 1/2" differance in the frame height. Will new springs even things out or is 1/2" within "normal"? I measured the frame just behind the cab and the heights are much more even there. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | May be a bent frame from an overload or a previous accident. Without a frame machine, it would be hard to tell for sure. Without a good foundation, you won't get a good end result. Just a thought, Scott | | | | | Joined: Jan 2007 Posts: 30 New Guy | | New Guy Joined: Jan 2007 Posts: 30 | Measure the difference at the back springs (from chassis to axle) to determine if it is the springs or the chassis. I was lucky, my problem was with the spacers under the bed. Now nice and very level! | | |
