3 members (Shaffer's1950, baldeagle, sron48), 61 guests, and 4 robots.
Topics128,015
Posts1,055,334
Members48,419
#235366 06/08/2007 4:04 PM
How do you go about lubing a truck that has sat for years.
Do you just clean the zerks and squeeze the grease gun with all your might? Or do you remove the zerk and try and clean out the old stuff that's in there.
"Happiness equals reality minus expectations" - Tom Magliozzi
#235367 06/08/2007 4:56 PM
if it takes grease, pump it in til it's pushing out all over .... if it doesn't take it fairly easily, clean the zerk and what you can reach, then try again, but usually the block is further in - can try pumping kerosine in to dissolve the cake
#235368 06/08/2007 5:05 PM
A little heat will soften the old grease too.
#235369 06/08/2007 6:23 PM
What I usually try to do is Try to give it grease and if it doesn't take I pull the zerk clean it well Then I add a little heat and if possible have someone move the joint your trying to get the grease into that usually will get it done.
1950 Chevy 3100
1982 Jetta Diesel
1994 Chevrolet K1500
1996 Pontiac Grand Prix
2001 Chevrolet Suburban 2500
No honey, I don't NEED more toys I just need something fast enough to do something stupid in.
