0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
Hi gang,
I'm not sure if this is the right forum for this question, but I need to know what those rubber doughnuts between the bottom of the cab and the frame are. I need to find some replacements for them so it would be handy to know what they are called. I finally got my new gas tank installed and yanked the old one out of the cab and realized the old tank mounts are held in place by the same bolts that go through those rubber doughnuts. So, as long as I have to take those bolts out anyhow, I may as well replace those too. Are replacements for those readily available?
David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
Cab mounts...check with Golden State...
golden-state-parts.com
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Thanks Stick!
Muchly appreciated!
David
My 1962 Chevy C-30
Cab mounts, as stated above. Check around for the best quality and pricing at:
www.lmctruck.com
www.bowtiebits.com
www.oldchevytrucks.com
www.classicparts.com
www.brotherstrucks.com
among others.
I hope this helps.
Tony
One of the best things i ever done to my 64 was replce these. If you don't mind a firmer ride go with the polyurathane mounts.
I just checked out the Brothers site and they have cab mounts for a 62, but it says "1/2 ton only" My truck is a one ton, is there really any difference in the cab mounts between a one ton and a half ton? Seems like the cabs would be identical.
David
My 1962 Chevy C-30
