1 members (Otto Skorzeny),
194
Mod | | | Forums66 Topics128,078 Posts1,056,055 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hi gang, I'm not sure if this is the right forum for this question, but I need to know what those rubber doughnuts between the bottom of the cab and the frame are. I need to find some replacements for them so it would be handy to know what they are called. I finally got my new gas tank installed and yanked the old one out of the cab and realized the old tank mounts are held in place by the same bolts that go through those rubber doughnuts. So, as long as I have to take those bolts out anyhow, I may as well replace those too. Are replacements for those readily available? David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Cab mounts...check with Golden State...
golden-state-parts.com
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Thanks Stick! Muchly appreciated! David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | One of the best things i ever done to my 64 was replce these. If you don't mind a firmer ride go with the polyurathane mounts. | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I just checked out the Brothers site and they have cab mounts for a 62, but it says "1/2 ton only" My truck is a one ton, is there really any difference in the cab mounts between a one ton and a half ton? Seems like the cabs would be identical. David
