Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (55shaker, Bill Hanlon, Jon G, 78buckshot, TrknGMC, Joe H, 1 invisible), 99 guests, and 3 robots.
Topics128,274
Posts1,058,436
Members48,490
#234904 05/30/2007 4:48 AM
Hi Guys, I'm just in the process of trying to do a passenger door removal on on my 53 1/2 ton. The bottom one will come out no problem but the top one seems to be hanging up on the lower spring. Any suggestions?
#234905 05/30/2007 4:49 AM
That's the hinge I'm talkin about by the way.
#234906 05/30/2007 5:55 AM
oldkoot, sounds like maybe You are trying to
remove door by taking the hinges with the door..
I found it easier to remove the hinge bolts from
the door, then slide the door off the hinges...
The spring on the upper hinge is whats hanging
stopping You. Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#234907 05/30/2007 6:03 AM
I guess that will be tomorrow nights project. Remove the door from the hinges than remove the hinges from the truck.Thanks Bill.
#234908 05/30/2007 8:20 PM
The hinges are usually stuck pretty tight to the doors anyway, I think you need them bolted to the truck to have the leverage to pull the hinge out of the door.
#234909 06/02/2007 5:03 AM
had same problem with mine , bolted hinges back to cab and then slid the doors off the hing arms after removing the bolts , they were tough to get to slide off but they did come off ..I think ill just leave teh hinges on the cab for paint . and slidethe doors back on the arms after
1952 Chevy Shortbed
Photos in Photobucket
