4 members (MRMEROTH11, Hotrod Lincoln, 52Carl, klhansen), 70 guests, and 2 robots.
Topics128,052
Posts1,055,773
#234888 05/29/2007 10:15 PM
Junior Member
Junior Member
i have got a 64'swb with a 327,3 speed ,body looks fair,small amount of rust,it's been took care of,runs really good,i've been offered,$2500.00,is that sound pretty fair,i'm used to 80's model 4x4's,this one is to old for me to know about
#234889 05/29/2007 11:49 PM
Ex Hall Monitor
Ex Hall Monitor
And you are wanting to know???????????
#234890 05/30/2007 12:08 AM
I guess you should sell. (it's not old enough for me)
#234891 05/30/2007 1:01 AM
sweetpea:
Your post will likely generate many responses. First of all, a 327 was not available in the C-series trucks until 1966. The 283 was the only sbc V8 available in 1964. I would check the block numbers and confirm what you have. The factory column shift 3 speeds were very common, therefore that does not boost the price.
Does it have any of these factory/dealer options:
power brakes
power assist steering
chrome side trim
chrome Custom cab sails
anodized aluminum grille
chrome front and rear bumpers
dash gauges, in lieu of warning lights
factory A/C
AM radio
If it has some of these options, it starts, runs and drives, and it is streetable, $2,500.00 is not unreasonable, however there are many other variables, that may move the price up or down. Rust in the floor boards, kick panels, rockers panels, cab corners, inner fenders, front fender tails, over the rear wheel wells or hood lip, will reduce the cost.
Post a few pictures and viewers will get a better idea of what you have. There are so many variables, it is hard to say what one is worth, however I own several and am rather discriminating when I purchase one. I hope this information is helpful.
Tony
#234892 05/30/2007 4:20 AM
id ask for more but thats just me.. i think the prices might be higher where i live(everything else is higher priced). good luck.
#234893 05/30/2007 9:17 PM
Riding in the Passing Lane
If it,s not rusted out too bad & runs I think it would be worth more than that. It,s hard to buy anything decent for less then 4-5 thousand. It,s true the older ones are worth more.
1972 Chevy c10 Cheyenne Super
#234894 05/30/2007 9:30 PM
A well equipped, original and complete '60-'66 Chevy truck will set it apart from most. There were many trucks manufactured during this era, therefore a unmolested, survivor that is complete, with little rust, is valued higher than the run-of-the-mill basic models with rust in the usual places. I hope this helps.
Tony
#234895 05/31/2007 11:44 PM
Junior Member
Junior Member
WELL,I REALLY THANK YA'LL,I DID CHECK THE VIN,AND RUN THE NUMBERS AND IT A '63,NOT A '64 LIKE I WAS TOLD,NOT KNOWING AT THE TIME,THAT THEY WAS THAT MUCH DIFFERENCE,I'VE BEEN TOLD THAT A '63 WAS THE LAST YEAR OF THE WRAP AROUND WINDSHIELD,IS THAT TRUE??ALSO IT DOES HAVE ALL THE CHROME,ON THE SIDES,CAB AND FRONT AND REAR BUMPER,AND GAUGES,I KINDA BROKE THE OL'LADYS CAMREA,SO I'LL STILL FIND A WAY TO POST SOME PICTURES
#234896 05/31/2007 11:55 PM
Thats correct, 63 is the last year of the wrap around windshield.
