Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (PullG, Tronman, 1 invisible), 133 guests, and 3 robots.
Topics128,288
Posts1,058,578
Members48,492
#234800 05/27/2007 3:06 PM
Is a governor for a GM overdrive the same as for a Ford, Nash or Packard? They look like the could be the same. Were they all build by Borg Warner?
if they look the same they prolly are - it's just a simple centrifigal switch that makes contact above a certain speed [rpm]
Yes they are the same. All were made by B-W. The solenoid and most internal parts swap as well, the main difference is really in the mounting adapter plate on the front of the unit.
Bill Burmeister
Thanks guys. There seem to be more advertised as Packard and Nash than there are Chevy.
