6 members (Shade Baby, baldeagle, Gdads51, treegrower, tclederman, DannyW), 64 guests, and 8 robots.
Topics128,014
Posts1,055,328
Members48,419
#234722 05/24/2007 1:48 AM
I've got bunch of non running ( 37,42, 46, 51 and 59 )chevy pickups. see photos:
http://new.photos.yahoo.com/jamesamackay/album/576460762399826474
I want to get the 46 running again. Someone did a poor job of putting in a 307 V8 and a 350 tran, who knows what 5 bolt rear end and some cut up 5 bolt front hubs. I want to make it look mostly origional but I'm not going to overdo it with exact year matches. Will the 51 or 59 frames fit without serious modification? The frame on it was cut up by the prior hot rodder. I would like to use the 59 because of the external drive shaft.
Does anyone have comparison specs on the changes to the half or 3 quarter ton frames?
#234723 05/24/2007 3:55 PM
3B Offline
Hy jim72051 I don't believe that any of the fifties frames will be an easy swap to your 46. the early 50s frame would be the best choice if you want to try, if my info is correct there is a wheelbase difference of 1" between the two frames. The 40s frames are tappered from back to front, as are the early 50s frames, the post 55A frames are rectangles, and lots of adapting would have to be done. As to 1/2 versus 3/4 ton there will be wheelbase differences, and heavier components to deal with, hope that helps.
#234724 05/25/2007 1:07 AM
The '42 is probably the closest fit.
The '51 or '59 front brakes can probably be adapted to the '46 front axle and the '59 rear axle is an easy swap to the '51 frame, but probably a little wide under a '46.
That's of course assuming they are all 1/2-ton frames, and you didn't say what they are...
#234725 05/25/2007 4:06 AM
A 47-53 1/2 ton frame may be tapered from front to back. But a 1 ton and 2 ton only taper from about the drivers seat forward, behind that the rails are parallel, I have one of each.
It sounds to me like you are trying to get away from someone else's poor choice in parts and fabrication by making some awkward choices yourself.
I would recommend you find a good frame for the truck you want to play with, and go from there. With a little searching I think you can turn up a good frame for less than $200.
1952 Chevrolet 3800 pickup
---All pictures---
