| | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23463 04/08/2005 1:37 AM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I'm ready to finish the re-installation of my engine and am down to re-filling the front universal bell housing. Is there a fill hole or can you do it through the speedometer drive gear and if so how?
My rule of life: You can have anything you want; you just can't have everything you want.
#23464 04/08/2005 3:36 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | evergreenw,
Is there a square head pipe plug near the rear of the transmission on the passenger side? Remove the plug and fill with transmission lubricant (SAE 90).
Tim | | |
#23465 04/08/2005 4:09 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | On an automatic transmission, the book says to pre-lube thru the speedo gear hole. About 3/4 cup if I recall.
I found that using a siphon (spelling?) bulb and tubing to slowly pump the fluid in worked well. | | |
