| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Anybody have an idea what a striped AD cab might weigh? I'm trying to figure how to lift the cab off the frame by myself. I'm thinking I might use my engine hoist with a boom extension (yet to be made)if it's not to heavy. :confused: | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Two people can almost move one with no doors.
I recommend an engine hoist like you mentioned, and someone to stand on the back for counterweight. Or a comealong hooked to something above works. Personally I use a chain fall for moving both my engine, transmission, and the cab. I can do it all by myself.
Grigg | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I used a chain hoist and a 4x4 through the cab and lifted mine with no problems, doors and all. | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | I ran straps under my cab and diagonal across inside the cab and picked it up with my engine hoist. Just take it slow the first time and make sure you have the weight balanced good. It worked out great. | | | | | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | I have done mine the same as fireout1 did. straps and an engine hoist. worked great. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | fireout1 and james.h., did you need an extension on the hoist? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Just a word of caution. I used straps too and ruined my stainless door window trim. Next time I'll remove the trim first. | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Here's an Old thread where I showed my old cab lifter I build. I've since built a better one out of steel that works even better, I've gotta find some pics of it in action and I'll post em'. Steve | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | KCMongo, Cool idea. I'll make something this weekend and give it a try. | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | No extension needed for mine plus no worries about bending anything topside with straps underneath. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I removed a cab with my engine hoist, just get it balanced right and go slow, it should be no problem. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | engine hoist not being used right now if you need to use it give me a call, or bring it out i'm sure the H will get it off one way or another... | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | How much vertical lift off the frame do I need if I want to hoist the cab from a ceiling?
Thanks! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I used a floor jack, some 4x4 posts and cinder blocks to lift high enough to roll the frame out from underneath cab | | |
