3 members (jmoore, gswbbc, Lightholder's Dad), 67 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#234461 05/20/2007 1:30 PM
Anybody have an idea what a striped AD cab might weigh? I'm trying to figure how to lift the cab off the frame by myself. I'm thinking I might use my engine hoist with a boom extension (yet to be made)if it's not to heavy. :confused:
My Trucks
Stuff I Collect
#234462 05/20/2007 1:50 PM
Two people can almost move one with no doors.
I recommend an engine hoist like you mentioned, and someone to stand on the back for counterweight.
Or a comealong hooked to something above works.
Personally I use a chain fall for moving both my engine, transmission, and the cab. I can do it all by myself.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#234463 05/20/2007 2:20 PM
I used a chain hoist and a 4x4 through the cab and lifted mine with no problems, doors and all.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#234464 05/20/2007 9:27 PM
I ran straps under my cab and diagonal across inside the cab and picked it up with my engine hoist. Just take it slow the first time and make sure you have the weight balanced good. It worked out great.
#234465 05/20/2007 10:46 PM
I have done mine the same as fireout1 did. straps and an engine hoist. worked great.
#234466 05/21/2007 3:56 AM
fireout1 and james.h., did you need an extension on the hoist?
My Trucks
Stuff I Collect
#234467 05/21/2007 4:57 AM
Just a word of caution. I used straps too and ruined my stainless door window trim. Next time I'll remove the trim first.
#234468 05/21/2007 6:24 AM
"MONGO"
"MONGO"
Here's an Old thread where I showed my old cab lifter I build. I've since built a better one out of steel that works even better, I've gotta find some pics of it in action and I'll post em'.
Steve
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#234469 05/21/2007 1:32 PM
KCMongo, Cool idea. I'll make something this weekend and give it a try.
My Trucks
Stuff I Collect
#234470 05/22/2007 4:59 AM
No extension needed for mine plus no worries about bending anything topside with straps underneath.
#234471 05/22/2007 3:38 PM
I removed a cab with my engine hoist, just get it balanced right and go slow, it should be no problem.
#234472 05/23/2007 12:27 AM
engine hoist not being used right now if you need to use it give me a call, or bring it out i'm sure the H will get it off one way or another...
Drive with Pride. mike j
family pic
#234473 05/23/2007 1:26 AM
How much vertical lift off the frame do I need if I want to hoist the cab from a ceiling?
Thanks!
#234474 05/23/2007 5:55 AM
I used a floor jack, some 4x4 posts and cinder blocks to lift high enough to roll the frame out from underneath cab
GMC: Get More Cash...
1958 GMC
My Webshots photos
