| | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23435 01/13/2002 1:33 AM | Joined: Aug 2000 Posts: 7 Member | | Member Joined: Aug 2000 Posts: 7 | I have had a Saginaw 4spd with a Hurst shifter in my '51 1/2t 3100 for 7 years. It has never gone more than 1-2 months without the linkage jamming in 2nd gear. I then have to pull over, stop the truck and pull the shifter into reverse to clear the jam. Then I drive using 1st, 3rd & 4th. I then reset the alignment and the shifting is fine for a couple more weeks...them boom, it jams again. I have replaced the Hurst shifter (twice), pulled and checked the gearbox. I have called Patrick's, Hurst(Mr. Gasket) and numerous tranny experts. We have checked & double checked alignment and reset the rods many times. The truck runs fine for a while and the set-up goes away. Everbody tells me this Hurst "set-up" is bullet proof...but I can't get it to work? What am I missing? Do I have to bend rods? Is there something in Patrick's conversion kit that I could have screwed up? I'm at the end of my rope and need some real creative help not a screwdriver in four holes. | | |
#23436 01/13/2002 3:57 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | I once had a simillar problem,for me it was the adjustment lock bolt would not stay no mater how i tightened it. Replaced it and was then ok.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
#23437 01/13/2002 6:54 PM | Joined: Aug 2000 Posts: 7 Member | | Member Joined: Aug 2000 Posts: 7 | How did you know it was the "stop" lock bolt? and how did you fix it? Where you only jamming in 2nd gear? thanks for the input. | | |
