0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#23435 01/13/2002 1:33 AM
I have had a Saginaw 4spd with a Hurst shifter in my '51 1/2t 3100 for 7 years. It has never gone more than 1-2 months without the linkage jamming in 2nd gear. I then have to pull over, stop the truck and pull the shifter into reverse to clear the jam. Then I drive using 1st, 3rd & 4th. I then reset the alignment and the shifting is fine for a couple more weeks...them boom, it jams again.
I have replaced the Hurst shifter (twice), pulled and checked the gearbox. I have called Patrick's, Hurst(Mr. Gasket) and numerous tranny experts. We have checked & double checked alignment and reset the rods many times. The truck runs fine for a while and the set-up goes away.
Everbody tells me this Hurst "set-up" is bullet proof...but I can't get it to work?
What am I missing? Do I have to bend rods? Is there something in Patrick's conversion kit that I could have screwed up? I'm at the end of my rope and need some real creative help not a screwdriver in four holes.
I once had a simillar problem,for me it was the adjustment lock bolt would not stay no mater how i tightened it. Replaced it and was then ok.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
How did you know it was the "stop" lock bolt? and how did you fix it? Where you only jamming in 2nd gear? thanks for the input.
