Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
#234066 05/16/2007 10:37 PM
Does anyone know what the specs would be for an alignment on a 1/2 ton '55 2nd series? I don't know if it matters, but I have radial tires on it. The local alignment shop only has specs back to '79.
Thanks!
I believe your answer is in the 55 2nd series shop manual located at the Keith Hardy site.
I don't know about the radial tires. A good tire shop should know what difference that makes if any.
http://chevy.tocmp.com/1955truck2shop/55ctsm0314.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
radials don't change anything
Thanks guys!
Riding in the Passing Lane
I don,t know what the specks are but I set the caster about 1-2 degrees pos. The camber is not adjustable unless you want to bend the axle. I set the toe in a little less then specks with radial tires. 0 to 1/16 in. toe-in.
1972 Chevy c10 Cheyenne Super
