1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
#234059 05/16/2007 9:34 PM
I'm trying to install an under bed tire carrier, and am having some problems. First of all does anyone know the bolt size on the drivers side where the carrier attaches,I think it might be 9/16". There's a welded in nut on the frame for the bolt I believe. The carrier doesn't seem long enough because using the other mounting point the bolt would be on an angle unless I'm using the wrong frame holes. I believe the carrier mounts diagonally. The new bolt I bought from LMC for for the passenger side won't fit through the hole from the top because of the length of it. It looks like a floor boards in the bed would have to be removed which doesn't seem right either. Any help is much appreciated.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
Junior Member
Junior Member
Hi Cal55,
I noticed nobody answered you. I hate when that happens, b/c it has happened to me before.
Hmmm I wish I knew... but I don't know how it is suppose to work on there. I have a 1963 and it doesn't have a under the bed spare carrier so I couldn't compare to give you an idea.
But you might want to check with folks from MarK bed parts, maybe they might have some sort of idea. Those tech guys sometimes are real helpful with diagrams and since they may come across it when folks are installing their bedwood, they might know.
Best of luck!
Tony
Thanks Tony,
I appreciate your help. I'm sure it's something simple or that I'm overlooking. I'm sure I'll figure it out in time. I'll try to contact Mark bed parts.
Thanks again,
Joe
k10 Offline
If you have an LMC catalog for 60-66 Chev, they have a good schematic in there. And of course the Assembly Manual has ALL the specs and nut sizes etc, etc. The carriers are placed into different positions depending upon the type of truck (ie longbed shortbed 4x4) and upon the size of the wheel/tire combo needed. Believe me, a picture is worth a 1000 words. grin
Thanks k10,
I do have an LMC catalog for 60-66 Chev.,I have looked at the schematic and it has helped somewhat. I didn't realize there were different positions for the bed size, so that's helpful too,mine is a short bed. There's a car show around here every Monday night. I went last Monday and there were a few 60-66 pick-ups there with the under bed tire carrier. I looked at their spare tire mounting, but I'll have to check them out again at the next show if they're there. It was a nice show and about 200 cars showed up.
Joe
If you put a slight bend in the pass side bolt slightly it will fit with the bed on, yeah I know you don't wanna bend new parts but you could also unbolt & raise the bed slightly.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks 64fleetside for the suggestion. I don't mind bending the bolt a little,no one will see it anyway, and it's only for the spare tire.
Joe
