3 members (Lostbuthaulinass, Ponchogl, RLB), 71 guests, and 3 robots.
Topics128,049
Posts1,055,743
#233775 05/12/2007 2:08 AM
Junior Member
Junior Member
Hey guys been a while since i have been on. I bought a 66 1/2 chevy the other day and already thinking of plans to convert the front pads to rotors. I know you can buy kits but looks pretty pricey to me. Any of you guys have any suggestions on what years fit as far as like upper and lower joints, rotors spindles? I read that a 70-74 would be was looking for something easier to have access to. The truck has a 350 already in it but the guy put a welding rod between the carb and the foot pedal. I heard a 95 chevy truck pedal and link would work? Thanks in advance any help in appreciated.
#233776 05/12/2007 2:41 AM
Front spindles are the same from '73-'87, so availability shouldn't be a problem. Just swap the balljoints and you're set. Chevy van '73-'94 and Suburban to '73-'91 are the same as pickup, too. On the gas pedal, the '95 uses a cable for a throttle body injection system, I'm not too sure how well that would work. You might be better to check with the parts houses to see if a repro is being made, or maybe Summit or Jegs for a cable linkage that's made to work with a carb.
Bill Burmeister
#233777 05/12/2007 3:12 AM
Junior Member
Junior Member
Many thanks longbox55.
#233778 05/12/2007 6:13 AM
badriand:
Congrats on the new addition. I can't speak to the disk conversion because I only do the factory power brake conversion on my '64-'66 Chevy trucks, however the throttle linkage for a transplanted 350 is the same for a factory 283 or 327. Let me know if I can help you in this category and good luck with your rig.
Tony
#233779 05/13/2007 3:51 AM
Junior Member
Junior Member
Thanks Tony, i was hoping you would chime in since you have a vast array of these trucks. I saw where someone suggested a power booster for the these (do you have any recommendations for that?)
#233780 05/13/2007 3:55 AM
Junior Member
Junior Member
Tony is there a kit you recommend for the power brake conversion?
