0 members (),
40
10
Mod | | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | I'm hoping someone can give me some advice. I've got a frozen filler bolt on my 54's differential cover. It has a square head, and appears to be 3/4". I tried the spanner and various pliers with no luck. Is heat my only other option? I don't have an oxy-acetylene torch, but was hoping to get by with one of those mapp-gas torches you can get cheap at my local hardware store. Will that give me enough heat to loosen things up? Also, I'm thinking a "double square" socket would be nice to have--or a big pipe wrench. Surely someone else has had this problem before. I did find one vendor the sells the bolt , so drilling it out could be an option. Thanks in advance. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Greg,
I have used a big pipe wrench with nice sharp teeth to get them off. They will usually be junk after this procedure, so ordering a new one in advance would be a good plan.
Stuart | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | I've used a short bolt with two nuts locked onto it and pounded it into the plug. I don't know if the impact of the hammer or the turning of the wrench loosened it but it came out. Be patient with it and work a little at a time. Sometimes a chisel or center punch will work to turn it out as well. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | These are common pipe threaded plugs and replacements are easy to get. You can buy sockets that fit them at a place that sells plumbing tools, and then get an impact wrench on it. If you decide to use a flame wrench I would remove the differential cover before heating it. You don't want to cook the oil inside.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I don't think the plug is a tapered pipe thread. The picture linked shows a face sealing type plug with gasket and straight threads. I know I have seen tapered pipe plugs in differentials, but this doesn't appear to be one. As Tim L. would say, "I'm sure someone will correct me if I'm wrong". Stuart | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | a propane torch will work fine heat it and cool it two or 3 times just that alone should brake it loose tap on it with a hammer a few times as your turning the wrench | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Greg , Try this one .....I AM A FIRM BELIEVER IN THIS PRODUCT.. soak it down with PB BLASTER ...the stuff just plain works !...let it set overnight an give it a try . Heck the plant i work in wont supply my Maint. crew with it so we all throw in what it takes to purchase it bye the case ...an we use it all the time on 3rd shift , an we keep it locked up our ANAL ORRIFICE sooos the folks on days dont use it all up ! hehehe | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Is your current plug an 'inny' or an 'outie'?
Ain't been a bolt or nut I haven't been able to get loose with WD40, a MAP Gas/Propane torch, and a little time.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I don't think those are straight threads on that bolt, and it isn't a common thread either. I think it is a NPSF, that is a finer thread. It is used where sealing is important, but I am guessing. You'll know when you get that rascal out. Let us know when you get 'er done. I am curious A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | The plug is an "outie" just like the picture linked in the first message of this topic. It sounds like the MAP gas and a big pipe wrench should do the trick. I just wanted to make sure there wasn't something obvious I was overlooking. I also have some PB Blaster and I'll be sure to pre-soak it before I work on it again. I'll also try to remember my camera and post up some pictures--we all like pictures! Thanks for the help. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I've heard good stuff about PB Blaster.. I haven't ever used it first hand, but some kind of WD/Liquid Wrench/PB Blaster/Kroll soaked in there, little heat, and a BFW outta have that bugger out of there with little trouble.
Some people replace those plugs with 'innies', that way when they need to pull 'em, they can take 'em out with just a big breaker bar or ratchet.
| | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | I agree--with the BFW being key. Sounds like a good excuse to buy a new tool! We are really just starting on this truck, and although it is is good shape, I know there will be many more cases like this. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you have a place shop near you that works on farm equipment they will most likely have 8 point sockets that fit square nuts. Alot of the older farm stuff has square headed nuts and bolts. I have a complete set and if the plug hasn't been rounded off the socket on a 1/2" impact will back them out. The 8 point sockets are also handy for using on the square end on thread taps since sometimes there isn't room for a regular tap handle to swing and being able to use a ratchet is faster and less tiring.
Evan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Better yet, get a 3/4" square socket. There's no chance of rounding the plug off wiht a square socket. I use a Wright part# 3324. Fits the plug on the master cylinder, too.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | If you have a welder, a trick i use is welding on a piece of bar stock or a nut to the plug. The heat from the weld will often loosen the stuck part. This work on bolts if you have enough sticking out to weld to. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Don't overlook - lefty loosey, righty tighty! | | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Hey guys, sorry for the late update, but my truck progress seems to move on a geological scale. Kids and other excuses keep me from getting out there more.
Anyway, my dad and I got that pesky bolt off. Mapp gas, big channel locks, a big hammer, and some WD-40 did the trick. We managed to beat up the square bolt head pretty good, so I'll have to pick up a new one next time I order parts. The good thing is that the differential is back together, not leaking, and full of fresh lube. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
