1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 24 Junior Member | | Junior Member Joined: Dec 2006 Posts: 24 | I am eventualy going to buy the 5 lug disc brake kit from either classics or brothers (probably the same one) for my 51 GMC my question is i know they offer the master cylinder for a disc/disc conversion. im sure that the master cylinder they offer has to be offered by a local parts store for a lot less $$$$ it has to be a particular master cylinder for a certain year chevy truck. does anyone know which one it is. I want the master cylinder to attach to the chassis like the original | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you're going to the disc/disc configuration then try a Corvette master. If going to a disc/drum configuration go with a mid 70's car or truck. You'll still need to fab a bracket to mount it to the frame or reinforce the firewall and install it there. You should also get an adjustable proportioning valve since the vehicle weights will differ from each other. Then there's the mounting of a booster to consider....... Scott | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | check ebay i purchase a new corvette style master with a 7 inch dual booster cheap, and made my own bracket to mount it. speedway has the best price on the 5 lug kit $240 ? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can buy a bolt on MC specific for your truck with booster and proportioning valve and comes with a bracket from most suppliers. I bought mine from Classic Performance Products.
~Jim
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | FOR ABOUT $125.00 I PURCHASED THE BOOSTER AND MASTER OB EBAY, I ALSO PURCHASE THE RESIDUAL VALVES ON EBAY | | |
