3 members (David Bush, 52Carl, Jon G), 136 guests, and 13 robots.
Topics128,078
Posts1,056,029
Members48,433
#233514 06/07/2007 2:54 AM
Junior Member
Junior Member
I am eventualy going to buy the 5 lug disc brake kit from either classics or brothers (probably the same one) for my 51 GMC my question is i know they offer the master cylinder for a disc/disc conversion. im sure that the master cylinder they offer has to be offered by a local parts store for a lot less $$$$ it has to be a particular master cylinder for a certain year chevy truck. does anyone know which one it is. I want the master cylinder to attach to the chassis like the original
#233515 06/07/2007 3:02 AM
If you're going to the disc/disc configuration then try a Corvette master. If going to a disc/drum configuration go with a mid 70's car or truck. You'll still need to fab a bracket to mount it to the frame or reinforce the firewall and install it there. You should also get an adjustable proportioning valve since the vehicle weights will differ from each other. Then there's the mounting of a booster to consider.......
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#233516 06/07/2007 3:05 AM
check ebay i purchase a new corvette style master with a 7 inch dual booster cheap, and made my own bracket to mount it. speedway has the best price on the 5 lug kit $240 ?
1949 SUBURBAN
#233517 06/07/2007 3:25 AM
You can buy a bolt on MC specific for your truck with booster and proportioning valve and comes with a bracket from most suppliers. I bought mine from Classic Performance Products.
~Jim
#233518 06/07/2007 5:04 AM
FOR ABOUT $125.00 I PURCHASED THE BOOSTER AND MASTER OB EBAY, I ALSO PURCHASE THE RESIDUAL VALVES ON EBAY
1949 SUBURBAN
