2 members (Otto Skorzeny, 1 invisible),
145
Mod | | | Forums66 Topics128,288 Posts1,058,581 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | Is there a difference between the car overdrive and the truck overdrive 3 speed? I found a trans, but the number on the overdrive unit is R10K-1. Everything I have found refers to R10H-1A or R10Q-1. If the main trans is different, could I just put the overdrive unit onto my truck 3 speed?
Thanks! Andy | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There isn't any difference from car to truck for Chevy/GMC. Could it be that the "K" that you're seeing is actually an "H"? Sometimes those old castings can be hard to read, especially if they're a little crusty with road crud. As far as the main trans goes, there are diffences between the O/D version and the standard, mainly it's in the extra holes for lube and the reverse lockout mechanism. As long as it's a GM trans, it will be a bolt in, no need to mount the O/D unit to the original trans. Check out my pix from my signature on the bottom to see how mine's setup.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Andy, Two minor differences but should not be a problem. The bottom mount holes on the pass car trans are not threaded so you need to use a longer bolt with a nut. Also you will probably have to use the side cover from the truck as the 2-3 shift arm points up on the car. Both levers on the truck point down.(except for 55 6 cyl) If both have the 4 bolt side cover you are good to go. Fred
| | | | | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | | | |
