2 members (RLB, 51 3804), 126 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#233321 05/06/2007 12:05 AM
Big Bolt Forum Co-moderator
Hello, I need to top up my master cylinder in 1948 two ton and before I add more fluid (looking for a leak) I want to know if I can use the synthetic dot 3 fluid. I didn't see anything else at the local automotive supply store, and I don't think I could trust asking the young lad behind the counter about the synthetic fluid. Is all brake fluid synthetic now and if the person who owned the truck before me put in non-synthetic can I mix them?
1948 Chevy 2-Ton
#233322 05/06/2007 12:23 AM
Most all brake fluids for at least the last 40 years or so are glycol ether based. The glycol ethers generally come from a vareity of petroleum sources including natural gas. Any DOT labeled brake fluid except DOT 5 is required to be compatible with any other DOT labeled brake fluid. Some of the DOT 5 fluids are silicone based and are not compatible.
Harold Wilson
41 Chevy 3/4 Ton
#233323 05/06/2007 12:24 AM
You cannot mix DOT 5 and other types. DOT 5 silcone is a purple color. Its good stuff but you need to do a all new brake system or at least flush the system well with a brake cleaner.
You can mix dot 4 and dot 3
#233324 05/06/2007 12:26 AM
Any DOT 3 fluid should be OK unless the previous owner put in DOT 5.
Harold Wilson
41 Chevy 3/4 Ton
#233325 05/06/2007 12:28 AM
There is no non-synthetic brake fluid. All brake fluid is synthetic. It's all "synthesized".
Harold Wilson
41 Chevy 3/4 Ton
#233326 05/06/2007 12:30 AM
There is synthetic DOT3 and 4. I would be leary of mixing though. And stay away from Dot 5. I tried it with all new components, it made the system leak.
If you can't find regular DOT3 at the store you go to, try a different one. Regular DOT3 is still availible.
Bill Burmeister
#233327 05/06/2007 12:39 AM
Thanks all. I top it up, pumped the air out and now I have brakes. However, in the future before I take this beast out on the road I would like to inspect the brakes. Mine is a 48 two ton and you have to pull the hubs just to take the drums off. There doesn't appear to be a leak, that I can find, but where did the fluid go???????????.
1948 Chevy 2-Ton
Since you have a 2 ton, do you have a brake booster on your truck? If you have a Hydrovac brake booster, you can leak into the cannister and you won't see an external leak. Had that happen on my Diamond T. You can leak several pints of brake fluid into that vacuum chamber. If so, I recommend you get it rebuilt, as it can be difficult to keep the master cylinder topped off.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Lightholder's Dad, I'll check that tomorrow.
1948 Chevy 2-Ton
Apprentice
Apprentice
Good news about your brakes. Moisture reduction is the key. With a fresh can of your dot3 you can accomplish alot with a clean syringe or turkey baster. Remove the fluid from the master reservoir and refill it. Drive for awhile and repeat the step. Doing this several times will clean your system and get you closer to pure and fresh dot3.
