1 members (RBs36),
172
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | I noticed my brake pedal seems kind of hard when braking and I'm not sure if I trust the brakes.It stops okay but it still doesn't feel right. The truck is a 60 C10 and has a brake booster that a PO put on,I don't think the truck came with one. I was wondering if the boosters bad or maybe the master cylinder. Any thoughts are appreciated.I was going to drive it tomorrow to a truck show about 50 miles away but I'm not sure if I should now because of the brakes. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Sounds like the Booster is not working. Check the vacuume line for leaks. If the line is ok, You probably have a bad booster. You will still stop ok, but it will take more pedal effort.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks Chris, I appreciate your reply,I'll check it out. It looks fairly new but who knows. At least I know it's safe to drive that way hopefully. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Pump the brake pedal a few times with the engine off. Then apply pressure to the pedal & start the engine. The pedal should drop a little. If not you don,t have vacuum to it or the booster is defective. Sometimes a system has some air in it from previous service & works its way out. You suddenly get a better pedal. It,s possible an emergency brake cable is sticking & not letting the rear brake shoes return. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks again for the replies. I looked at the vacuum hose going to the booster and the PO had the pcv valve and the booster connected to the same hose,using a plastic T fitting.I ran the booster vacuum line separtely and it seems like the brakes are much better unless it's my imagination. I don't think the booster was getting enough vacuum before. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | There is an a fitting made specifically for that connection, PB, PCV to manifold. I have one on my 292.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks Larry, I was at a car/truck show yesterday and noticed that on some trucks I saw. I'll have to locate a fitting for it like that. I was going to connect the pcv valve to the back of the carburetor,but I like your suggestion better. Joe
