8 members (Ponchogl, Gabes-trucks, Wickedbass, Otto Skorzeny, 52Carl, dt235sd, BC59, 1 invisible), 138 guests, and 1 robot.
Topics128,081
Posts1,056,076
Members48,434
#233314 05/05/2007 2:41 PM
I noticed my brake pedal seems kind of hard when braking and I'm not sure if I trust the brakes.It stops okay but it still doesn't feel right. The truck is a 60 C10 and has a brake booster that a PO put on,I don't think the truck came with one. I was wondering if the boosters bad or maybe the master cylinder. Any thoughts are appreciated.I was going to drive it tomorrow to a truck show about 50 miles away but I'm not sure if I should now because of the brakes.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
#233315 05/05/2007 3:05 PM
Sounds like the Booster is not working. Check the vacuume line for leaks. If the line is ok, You probably have a bad booster. You will still stop ok, but it will take more pedal effort.
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
#233316 05/05/2007 4:46 PM
Thanks Chris,
I appreciate your reply,I'll check it out. It looks fairly new but who knows. At least I know it's safe to drive that way hopefully.
Joe
#233317 05/05/2007 10:29 PM
Riding in the Passing Lane
Pump the brake pedal a few times with the engine off. Then apply pressure to the pedal & start the engine. The pedal should drop a little. If not you don,t have vacuum to it or the booster is defective. Sometimes a system has some air in it from previous service & works its way out. You suddenly get a better pedal. It,s possible an emergency brake cable is sticking & not letting the rear brake shoes return.
1972 Chevy c10 Cheyenne Super
#233318 05/06/2007 12:45 PM
Thanks again for the replies. I looked at the vacuum hose going to the booster and the PO had the pcv valve and the booster connected to the same hose,using a plastic T fitting.I ran the booster vacuum line separtely and it seems like the brakes are much better unless it's my imagination. I don't think the booster was getting enough vacuum before.
Joe
#233319 05/06/2007 3:12 PM
There is an a fitting made specifically for that connection, PB, PCV to manifold. I have one on my 292.
Larry
I don't own a vehicle that isn't old enough to drink.
#233320 05/07/2007 2:08 PM
Thanks Larry,
I was at a car/truck show yesterday and noticed that on some trucks I saw. I'll have to locate a fitting for it like that. I was going to connect the pcv valve to the back of the carburetor,but I like your suggestion better.
Joe
