1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | Can anyone email me pictures of the original heater units just below the glovebox? I trying to determine if mine is the original but have been unable to find any oictures etc. Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop blue the set is: factory installed deluxe model, factory installed standard, and dealer installed 'basic', which seems to be the most common you'll find pics of 3 different styles of TF heaters here - there's a 4th less common style I haven't got pics of up yet - eventually there'll be a 'tech tip' on the TF heaters .... when life allows time Bill | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Wow, thanks Red!!
My truck currently doesn't have any dash controls, just a small light in a hole drilled in the heater control delete panel in the dash.
Does one of the models have a set up like this?
I figured it may have been for an aftermarket heater, but now that I know there were four different heaters... | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I thank you also, Red. For posting the link to the pics instead of e-mailing them. Sometimes conversations get personal and we with the same questions don't see the responses.  Thanks again, some very nice pics!  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the deluxe version was the only one that had the fancy dash control panel, the others just have a variable resistance switch [hi-med-lo] in that delete plate - the dealer installed seems to mostly have had a lighted plastic knob switch like the one visible upper left here - the factory standard had a knob that matched the other dash knobs, as seen upper left here I also got a pic up of the 4th 'standard' style, that I think was available 55-57 here - would have the same rotary switch with matching knob - I'd expect yours would match one of those shown as by 57 there wasn't much need to go with 3rd party heaters Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | agree Fred - I try to make as much info as I can avalable and pics are where it's at ..... and yes, on your last pic, that little tube on your wiper bezels is where the washer hose goes, along with the nozzles [available repro] that go where there's a small slot screw on the outside face
Bill | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Just to add to what Bill posted above, I had to replace part of the heater control panel in my Cameo, which has the deluxe heater, many years ago and was able to use the parts from a control unit from a 55 Chev car. I can't remember whether the unit interchanges completely, but the guts were identical. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
