1 members (dt235sd), 141 guests, and 3 robots.
Topics128,260
Posts1,058,319
Members48,485
#233094 05/01/2007 11:48 PM
Can anyone email me pictures of the original heater units just below the glovebox? I trying to determine if mine is the original but have been unable to find any oictures etc. Thanks!
#233095 05/02/2007 2:32 AM
welcome to the shop blue
the set is: factory installed deluxe model, factory installed standard, and dealer installed 'basic', which seems to be the most common
you'll find pics of 3 different styles of TF heaters here - there's a 4th less common style I haven't got pics of up yet - eventually there'll be a 'tech tip' on the TF heaters .... when life allows time grin
#233096 05/04/2007 6:24 PM
Apprentice
Apprentice
Wow, thanks Red!!
My truck currently doesn't have any dash controls, just a small light in a hole drilled in the heater control delete panel in the dash.
Does one of the models have a set up like this?
I figured it may have been for an aftermarket heater, but now that I know there were four different heaters...
Scott
http://waywardgarage.com
1957 Chevy 3100
#233097 05/04/2007 6:48 PM
I thank you also, Red. For posting the link to the pics instead of e-mailing them. Sometimes conversations get personal and we with the same questions don't see the responses. ohwell Thanks again, some very nice pics! grin
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
#233098 05/04/2007 6:55 PM
the deluxe version was the only one that had the fancy dash control panel, the others just have a variable resistance switch [hi-med-lo] in that delete plate - the dealer installed seems to mostly have had a lighted plastic knob switch like the one visible upper left here - the factory standard had a knob that matched the other dash knobs, as seen upper left here
I also got a pic up of the 4th 'standard' style, that I think was available 55-57 here - would have the same rotary switch with matching knob - I'd expect yours would match one of those shown as by 57 there wasn't much need to go with 3rd party heaters
#233099 05/04/2007 7:02 PM
agree Fred - I try to make as much info as I can avalable and pics are where it's at ..... and yes, on your last pic, that little tube on your wiper bezels is where the washer hose goes, along with the nozzles [available repro] that go where there's a small slot screw on the outside face
#233100 05/04/2007 7:59 PM
Just to add to what Bill posted above, I had to replace part of the heater control panel in my Cameo, which has the deluxe heater, many years ago and was able to use the parts from a control unit from a 55 Chev car. I can't remember whether the unit interchanges completely, but the guts were identical.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
