3 members (FAST55, MickeyP, Rusty Heaps), 49 guests, and 1 robot.
Topics128,049
Posts1,055,701
#233047 05/01/2007 12:34 AM
thought someone could help me to decipher the last portion of the vin code for my 58 cameo pickup. so far i haven't heard a word. are'nt there any code busters(vin)out there? any help will be greatly appreciated. thanks
vin# V3A58L 102212
dave hudson
#233048 05/01/2007 1:00 AM
V = V8
3A = 1/2T
58 = 1958
L = LosAngeles plant
102212 = assembly sequence number [serial#]
#233049 05/01/2007 2:27 AM
There you go! LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#233050 05/08/2007 3:02 AM
I read earlier that all cameos were built in Flint? Is that true?
#233051 05/08/2007 3:24 AM
no it's not .... your VIN shows the truck was built in LA, and I wouldn't be suprised if more Cameos were sold in California then elsewhere - why would they ship a complete truck clear across the country when they could get by just shipping some fiberglas panels, the entire truck except for the plastic rear parts was identical to any 1/2T step side, fully optioned
any truck down the line in any of the 10 or 12 plants was either a "standard", spec truck for the lot, or an ordered "job number", assembled to order in among the rest
#233052 05/08/2007 4:29 AM
Bill you seem to know your chevy trucks. Is there a way to establish by the vin what number truck (specifically)Cameo my truck was built. ie; #212 or 12 or 2212. They only made 1405 in 58 so 2212 may represent the production # of all or various 1/2 ton p/u,s produced in that year. Your thoughts are appreciated. Thanks, Dave
dave hudson
#233053 05/09/2007 5:38 PM
I'd guess the 2212 is just the order your truck was produced in that specific plant.. and the 2212 may not even represent the production order of that particular model (1/2 ton) but could just be the 2212th truck that particular plant spit out that year.
The Stovebolts Own VIN Buster accurately decodes U.S. built Chevrolet trucks from 1929 thru 1964.. but just tackles the basics.. Year, Model, Wheelbase, Plant, and Month where available.
#233054 05/09/2007 8:19 PM
yes, what Fumblin sez, the different models weren't numbered sequentially, just part of the general flow, it would have been the 2,212th truck of any model made in LA for that calender year, it might have been the only Cameo on a given day, and with something like 275,000 commercial vehicles built in '58 [don't know what percentage was produced at LA, but I'd think at least 30,000 or more], and the Cameo dropped mid year, I'd guess it was built at the end of 57, when 58 production first started, and likely before the beginning '58 .... the resto pak from GM might have more specific info from your VIN, tho' I don't think they did too well with records back then
and you may get some clues about the month built from date codes on original parts, like block casting, trans, rear end
#233055 05/09/2007 8:40 PM
I imagine Chevrolet numbered their production the same way GMC did. If so each plant and each series (i.e.3100, 3800, etc.) started at 1001.
#233056 05/09/2007 11:27 PM
cletis has a point. this was taken from the Stovebolt Tech Tips section regarding '56 thru '59 trucks..
Quote
Last was the the sequence number (6 digits and started with 001001 at each plant)
#233057 05/10/2007 1:33 AM
Cletis - the 1001 start was for pre-53 production, in 53 they changed to 001001 to start, until 55, in 56 the numbering sequence started at 100001, at each plant for general production, not each series .... it continued that way until 1971 when it changed to 800001 starting number each plant .... Peg! the tech tip is wrong grin
#233058 05/10/2007 4:26 AM
glad to see i got you guys motivated. its all very interesting and i'm certain i will pick up some good tips from youz guys. thanks for all the input.
dave hudson
