Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (G508, dt235sd, DoubleB), 173 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
Page 2 of 2 1 2
Thanks Alan,
I'll give it a try on some chrome ralley wheels I have that have some surface rust or maybe more than that on them.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
thanks AD_Pickup, the prices aren't bad, and that is a nice size
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
tin foil
Jim & Caroline
What's your view on Gibb's AD_pickup?
Colin, no views... I have never used it.
Ok.. so what's the word? Any of you guys who said they bought this stuff tried it out besides Robin?
Nobody? I count five people in this thread who were going to bag some of this stuff.. just want to see if this miracle spray lived up to the hype.
Alan:
I received my GIBBS last week and promptly applied it to three grilles on my '65 & '66 Chevy trucks. Two of the grilles were the remanufactured units that come from LMC/Chevy Duty and the likes. They had developed some surface rust on the top surface of the lower bar. Without steel wool, I was able to remove the surface rust while applying with a terry cloth towel. The third grille was a factory anodized aluminum unit that needed to be freshened up. The GIBBS did a nice job on all three. I will be using it from this point forward. Thanks for the tip.
Tony
PS - Haters need not reply!
I was wondering if any of the non-believers knew that snake oil is a very good rust inhibitor?
Don't hate the player, baby.. hate the game.
Robin, who's opinion I trust says Gibbs works great for coating chrome and preventing reappearance of minor surface rust.. and was less expensive than comparable products.
But was the, and I quote, "highly touted capabilities of penetrant, rust remover etc that I found it lacking in."
That ain't hating, that's being skeptical when such a wide range of claims are made about a product.. especially ones like one Gibbs Brand distributor makes.. that PC professionals use Gibbs Brand to lubricate the bearings in their hard drives.
Uhh huh. Sure they do. Anybody who believes that probably not only lubricates the bearings in their brain (via their nose) with Gibbs, but also uses Gibbs Brand to treat yeast infections and ringworm.
And apparently, Gibbs Brand was as effective at removing rust from an aluminum toolbox as a soggy wad of tolit paper would have been.. which might explain why AD didn't report great results when trying to clean up his aluminum step pads.
So no.. it's not 'hating'.. it's being skeptical. Your mileage may vary.
I'm still waiting to hear from the guys in this thread who bought the stuff to hear how it worked out for them.
4-5-6 Chevy trucks wrote:
Quote
:confused: No criticism is allowed...I dont understand....
Jed
Offline
Fumblin,
The verdict is still out. I purchased the product, and even received it. Haven't had a chance to use it yet.
Will attempt to do so this weekend, and report back on the results.
Here's a good introduction to Gibbs, with examples and pics how it works.
This page just got updated last week....
http://www.roadsters.com/gibbs/
I like this stuff - works well for me.
For application I use cheap paint brushes.
I use it mostly to prevent rust on bare metal.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
Jed
Offline
Fumblin,
I was able to work on the grill a bit this afternoon. Didn't work long, or very hard at it, but as promised, I wanted to show you and the rest of the followers of this thread my results.
In this photo, I cleaned half the grill with Gibbs, and left the other half clearly showing the amount of rust I had to deal with.
I'll let the rest of you guys judge for yourselve's. However, for me, the $20+ bucks I spent on the Gibbs was worth the results I received.
The grill that started this thread
The best part is, you won't see any rust come *back* again!
Note: There's a difference to be considered between a Snake Oil Salesman and a Friend.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
I have a question. If you follow the link for David Mann at roadster.com which displays the Ford 32 Coupe and another vehicle he has sprayed with Gibbs to prevent the rust from returning after he DA'd it (miraculously filling in dents and holes), exactly what is the correct procedure for removing Gibbs before painting? I realize they state you can paint over it, but I would seriously doubt any paint manufacturer is going to agree to this. You want an epoxy primer to adhere itself to the metal not some intersealant. Need to use the DA again? Will a standard Wax and Grease remover take care of this? Anyone who has used this stuff for a long time ever painted over it?
Jed, thanks for the update. I've been following this thread hoping to see results from fellow Stovebolters.
Good thing you were wearing trousers during that photo shoot!
Joe
'67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor
"Tighten until the stud snaps, then back off half a turn."
Quote
Originally posted by robin58:
... exactly what is the correct procedure for removing Gibbs before painting?
From what I've read, after applying GIBBS, you use the suggested cleaner and paint. Period.
I have a nephew who is a pro' painter ... he couldn't believe this was true -- until he tried it. He said it *is* so! You don't need a primer ... but I think I'd prime anyway.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Jed
Offline
Dogris,
That's funny as hell!
It took me a minute or two to figure out your trouser's comment. I hadn't even noticed the reflection in the grill picture. Probably would have been quite the site had I been wearing shorts, rather than the jeans.
Jed..
After seeing your results, and hearing Robins review, i'm sold on Gibbs for cleaning up and protecting chrome.
If you get the chance to put Gibbs to the test on rust on metal, or using it as a penetrant, let us know.
Page 2 of 2 1 2
