6 members (Otto Skorzeny, Hotrod Lincoln, klhansen, MickeyP, DadsFirstPickup, Woodcmiami), 114 guests, and 1 robot.
Topics128,043
Posts1,055,609
#23281 11/28/2003 5:44 PM
I remember reading somewhere on the bolt but can't find it. Example: if the truck turns to the left when you apply brakes, is it because the left shoes are making contact before the rights? If so do you back off the lefts or tighten up the rights.
Since I just replaced the W/C on my front left wheel it would seem that it might be grabbing too soon as compared to the front right. I think it would be good for me to go and adjust the rears while I'm at it.
Finally when it comes to adjusting, do most of you guys tighten up the pads to the point of a good grag and then back off the pads until zero drag or just a little drag.
what a drag this subject has become grin
Craig
#23282 11/28/2003 6:21 PM
It can also be caused by air in the lines.
54 3100 with 235
62 flatbed dump C60 with 261
#23283 11/28/2003 6:26 PM
When I am adjusting brakes, I like to cinch them up tight, then back off the adjuster until I get a little drag. On the front brakes, you may have to play with them a bit to eliminate the shoes pulling to one side or the other..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#23284 11/28/2003 8:21 PM
Bondo Artiste
Bondo Artiste
I did mine exactly the way "53 4 me" did and they are dead on.......
~ Phillip
#23285 11/29/2003 4:17 AM
My old man taught me to go till they stop turning and back them off evenly, he is 80 now and worked and taught auto for years I never had a problem doing it that way
#23286 11/29/2003 4:33 AM
The rule of thumb i was taught by an old timer to adjust them is by giveing them a spin.Ajust each wheel so that it will spin one revolution.Works great for me.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#23287 12/09/2003 5:09 PM
The method mentioned by SlowRider will generally work well, but use caution.... If your drum es even slightly out of round, one will drag a little sooner, but not truly be adjustled equally. This will cause the same pull you are trying to eliminate.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#23288 12/10/2003 5:51 PM
Was there brake fluid on the shoes? That will cause them to grab and means a new set of shoes for the front
Fred
52 3600
69 C-10
#23289 12/10/2003 6:51 PM
I would think that front brakes would have to be seriously out of adjustment before pulling would occur. Any time I have experienced pulling on any vehicle was due to a problem with a wheel cylinder (frozen or leaking).
#23290 12/15/2003 7:03 AM
You stated that you replaced the "left" front W/C, Yes it "working" better than the right, or seemingly "grabbing", because the left side is now more efficient in braking. When it comes to replacing W/C's, "ALWAYS" replace "BOTH" sides, so they are then equal in their function. If problems still persist after replacing "Both" sides, be sure to follow all the advice already given.
#23291 12/16/2003 5:31 AM
Yes, there was a little fluid on the drum pads upon inspection. Since I'm going to be replacing the entire frontend assy (soon), I'll deal with the pulling for now, hoping it will go away when I change the entire front end assy.
Craig
