1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 8 Junior Member | | Junior Member Joined: Feb 2007 Posts: 8 | Has anyone heard of running water based cutting oil/fluid in a cooling system? I was at a show and a guy with a '50 D*dge said he was running 50% cutting fluid. He said if it lubes machines and prevents rust, it should do the same in an engine. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It's an old time solution, but the fact is that modern anti-freeze protects better, gives your cooling fluid a higher boiling point, and doesn't heat as quickly as oil based fluids. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | PoorOldSod,
Mixing Soluble oil with coolant was very common years ago. It supposedly kept the water pump lubricated and who knows what else. Maybe it raised the freezing temperature of the water too!
Stuart | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My dad always used soluble oil in his cars, he was a petroleum industry employee and the engineers told him it was beneficial. Possibly later discoveries have come up with some superior products, but something in the water seems to be a good idea. I use anti freeze these days, since I ran out of dad's soluble oil. | | | | | Joined: Feb 2007 Posts: 8 Junior Member | | Junior Member Joined: Feb 2007 Posts: 8 | Thanks. And here I thought this was some brand new breakthrough solution to keeping on old six going. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Hey, Stuart, don't you mean LOWER the freezing point?!? I don't know about adding any oil to the cooling system like that. It might be good for the pump, but what does it do to the rubber components? Most oils will attack rubber and soften and/or destroy it. I'd stick with antifreeze, about a 50/50 mix, maybe with a bottle of Redlines Water Wetter or Royal Purples Purple Ice. I've used Water Wetter and it does work. And stay with the green stuff, Dex-Cool isn't compatible with the older pumps and the "non-toxic" stuff isn't as efficient.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill, Sheesh..I guess that's what I meant...I'm losing my mind! Stuart | | | | | Joined: Nov 2004 Posts: 2,407 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,407 | Cutzal 50-50 (if I remember correctly) is a typical mineral oil based coolant. We used to have that in some old multi-spindle bar machines at work. It was milky looking, I never did care for the stuff. It used to breed bacteria, unless we aerated the coolant tanks. I wouldn't put that in any of my engines. We eventually switched most of our machines to a full synthetic product. For my trucks, I'll stick with a good antifreeze.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Yesterday’s soluble oils are nothing like today’s coolants. Some, especially synthetics can attack o-rings or seals on machine tools and even gum them up. Most machine tool coolants are mixed 20 to 1 or about 5% and drums of used coolant will split if left outside in winter. Not worth the risk I think.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i would stick with now day's coolants, much better than the older stuff 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | WATER WETNERS? We use water wetners every day, at least I hope we all do. Soap is a water wetner, just don't put too much in your radiator.
~Jim
